When I see a beautiful Lo-Hi cap (7018) I stop and stare, especially on a 2 inch pipe in test position. I aim to be the best welder ever ,but my signature is not allowing me to accomplish my goal. MaYdAy!!!MaYday!!Welder needs HELP! Give me your best advise for my problem. Thank you and keep up the good work.
Oct 13, 2010 Rating
MOVIMIENTO DE LA SOLDADURA by: PEPON
DIGANME QUE MOVIMIENTO ..LLEVA EL STICK WELD..AL RELLENAR Y TAPAR EL HOT PASS .. SEAN ESPECIFICOS 3/32, 7018..QUE AMP..REQUIERE ? ESPERO RESPUESTRA ASAP.
Nov 05, 2009 Rating
WELDING 6G by: BIG JOHN
WELL MY SIGHT OF VIEW IS THIS ALL THE INFO IS VERY HELP FUL AND USEFUL TO ALL WHO WANT TO BE A GOOD WELDER WE HAVE TO HELP ONE EACHOTHER OUT AND FOR THE GUY WHO SAID THEY TELL YOU TO USE 6010 TO SEE IF YOU KNOW WHAT YOUR DOING I HAVE TO DISAGREE SOME CODES AND STANDARDS REQUIRE DIFFERNT RODS AND FOR ROOT AND HOT AND CAPP ALL THE SAME JUST IN DIFFERNT SEQUENCES ITS ALL TO THE TESTING INSPECTOR AND KEEP UP THE GOOD INFO
Oct 07, 2009 Rating
p5 on p5 by: james
hey did you say you were told to run a 6010 root with a 6010 hotpass then finish filling it in and capping with 7018? just wondering because my instructor told me you will bust out if you run a 6010 hotpass over a 6010 root, and that they sometimes tell u thats what they want just to see if you know what your doing.
Oct 05, 2009 Rating
passed the x ray! by: joe
Thanks again for your advice Jody. I passed the x ray and more importantly walked away from that test knowing that was a solid joint. Once again thank you and great job on the site, I think it is great and have been talking it up to the boys at the hall.
