XML RSSSubscribe To This Site
XML RSS
Add to Google
Add to My Yahoo!
Add to My MSN
Subscribe with Bloglines
Home
General Welding Topics Latest & Greatest
Forum
Welding Certification
Welding DVD sale
TigFinger Heatshield
Welder Shortage
contact us
Welding Schools
Amazin Blaze
T Shirts
types of welding
Start a Welding Biz
Welding Test Q&A
Tig Welding TIG welding test
Tig Articles
Tig Welding Pipe
Tig Basics Course
Advanced Tig Tips
Tig Aluminum Drill
Tig Settings
Pulse Tig
TIG Weld Aluminum
Welding 4130
Welding Stainless
TIG  Welding
Welding Titanium
Tungsten Sharpeners
Tig Noobs click here
Tig Supplies
Mig Welding Mig Welding tips
Uphill Mig
 MIG Procedures
MIG Supplies
Mig Videos
20 Best Mig Tips
3g welding test 2
Stick Welding
Arc Welding project
Videos Video Archives
Scratch Start Tig
welding video links
TIG Videos
Welding Videos
Welding Table
Miller Welding
 Q&A
welding steel
Welding Hats
Welding DVDs
Reviews lincoln power mig
hobart trek 180
Hobart 115v mig
Everlast Welders
plasma cutter review
How Not to weld
Auto Dark Helmets
Hobart Welding
Lincoln Mig welder
Welding Links
Chinese Tig Welder
Safety Welding Lawsuits
Welding Safety Tips
OXYFUEL Safety
Welding Curtains
Welding Tips by U
Welding Jobs
More Tips migging cast iron
Gas Welding
Welding Cast Iron
Mig Stainless
Welding Galvanized
Laser Welding
underwater welding
mig techniques
Plasma Cutting
Motorsports Welding
More Welding Tips
 TIG TIPS
more tig tips
even more tig tips
WeldingTest Q&A
WyoTech
MIG Q & A
TIG Welding Q&A
Site Map
Weld like a Girl
Miller Welding Table
privacy policy
WeldTec Torches
weld razor blades
Brazing
How to Mig Weld
Miller Helmet
Welding Pictures
Welding Techniques
ARC welding videos
Welding Aluminum
Comments for
Corner welding 1/16th aluminum plate
Jan 24, 2010
Tungsten Choice
by: Adric Maggs
Hi there,
did you mean that your using a thoriated tungsten electrode sharpened to a 'bluntish'point?
In my training through my apprenticeship & from other tradesman I have always been told for aluminium to use a zirconiated tungsten(aluminium only),apparently mildly radioactive,so you can use ceriated or lanthiated as alternatives(both can be used for for mild steel,stainless steel,or aluminium)And then for aluminium use it broken off square/clean or balled up(increase amps or use DC+ to ball up)Try to direct your ark evenly between both sections being joined.I find at the start sometimes it will only direct at one surface at a time,so I aim at one & then the other & quick as possible give a wipe with the filler rod between both of them,then the ark stabilizes.Better to start with amps too low and work up,rather than have it all drop away.The aluminium oxide coating melts at a higher temperature than the aluminium itself,so make sure its as clean as possible(grind/sand if necessary).If it is a bit old or dirty a few 'dabs' or 'wipes' with the filler rod can help get the molten pool started!
Good luck hope it works out for you!Aluminium is great fun to weld when you get the hang of it.
Adric Maggs
Simply click here to return to tig forum
Return to Corner welding 1/16th aluminum plate
