XML RSSSubscribe To This Site
XML RSS
Add to Google
Add to My Yahoo!
Add to My MSN
Subscribe with Bloglines
Home
General Welding Topics Latest & Greatest
Forum
Welding Certification
Welding DVD sale
TigFinger Heatshield
Welder Shortage
contact us
Welding Schools
Amazin Blaze
T Shirts
types of welding
Start a Welding Biz
Welding Test Q&A
Tig Welding TIG welding test
Tig Articles
Tig Welding Pipe
Tig Basics Course
Advanced Tig Tips
Tig Aluminum Drill
Tig Settings
Pulse Tig
TIG Weld Aluminum
Welding 4130
Welding Stainless
TIG  Welding
Welding Titanium
Tungsten Sharpeners
Tig Noobs click here
Tig Supplies
Mig Welding Mig Welding tips
Uphill Mig
 MIG Procedures
MIG Supplies
Mig Videos
20 Best Mig Tips
3g welding test 2
Stick Welding
Arc Welding project
Videos Video Archives
Scratch Start Tig
welding video links
TIG Videos
Welding Videos
Welding Table
Miller Welding
 Q&A
welding steel
Welding Hats
Welding DVDs
Reviews lincoln power mig
hobart trek 180
Hobart 115v mig
Everlast Welders
plasma cutter review
How Not to weld
Auto Dark Helmets
Hobart Welding
Lincoln Mig welder
Welding Links
Chinese Tig Welder
Safety Welding Lawsuits
Welding Safety Tips
OXYFUEL Safety
Welding Curtains
Welding Tips by U
Welding Jobs
More Tips migging cast iron
Gas Welding
Welding Cast Iron
Mig Stainless
Welding Galvanized
Laser Welding
underwater welding
mig techniques
Plasma Cutting
Motorsports Welding
More Welding Tips
 TIG TIPS
more tig tips
even more tig tips
WeldingTest Q&A
WyoTech
MIG Q & A
TIG Welding Q&A
Site Map
Weld like a Girl
Miller Welding Table
privacy policy
WeldTec Torches
weld razor blades
Brazing
How to Mig Weld
Miller Helmet
Welding Pictures
Welding Techniques
ARC welding videos
Welding Aluminum
Comments for
Heat Rises and preheats your next bead
Feb 25, 2010
To rebutt rons post on heat travel
by: geezer
Heat rises?
by: Ron
IMHO, heated air does rise because the heated air has the room to rise(air gets lighter as heated). The heat in metal, on the other hand, has nowhere to go, and not enough time to do it. So I don't think it makes to much difference, either weld up or down, the heat will just radiate out from the heat source until disipated in surrounding metal.
Ron
Ron ,I agree with some of your thinking, however you discount the effect of the hot gases that would naturally flow upward ahead of your weld preheating the material. This effect cannot happen in downward welding as the heat would rise back up over something already welded.
Jody's claim of reduced voltage required for the same penetration in upward travel would sustantiate this preheat effect.
To further simplify the issue, when you apply a torch to solder a pipe in the middle of a pipe. The solder will melt quite easily on the top of the pipe, but no so easily on the bottom of the pipe.
When you want to heat something up you apply the heat to the lowest point, Why ,cause heat rises better than it travels downward.
Feb 06, 2010
starstarstarstar
Heat rises?
by: Ron
Ron
Simply click here to return to mig welding techniques
Return to Heat Rises and preheats your next bead
