XML RSSSubscribe To This Site
XML RSS
Add to Google
Add to My Yahoo!
Add to My MSN
Subscribe with Bloglines
Home
General Welding Topics Recent Updates
_forum
Welding Certification
Welding DVD sale
TigFinger Heatshield
Welder Shortage
contact us
Welding Schools
Amazin Blaze
T Shirts
types of welding
Start a Welding Biz
Welding Test Q&A
Tig Welding TIG welding test
Tig Articles
Tig Welding Pipe
Tig Basics Course
Advanced Tig Tips
Tig Aluminum Drill
Tig Settings
Pulse Tig
TIG Weld Aluminum
Welding 4130
Welding Stainless
TIG  Welding
Welding Titanium
Tungsten Sharpeners
Tig Noobs click here
Tig Supplies
Mig Welding Mig Welding tips
Uphill Mig
 MIG Procedures
MIG Supplies
Mig Videos
20 Best Mig Tips
3g welding test 2
Stick Welding
Arc Welding project
Videos Video Archives
Scratch Start Tig
welding video links
Welding Videos
Welding Table
Miller Welding
 Q&A
welding steel
Welding Hats
Welding DVDs
Reviews lincoln power mig
hobart trek 180
Hobart 115v mig
Everlast Welders
plasma cutter review
How Not to weld
Auto Dark Helmets
Hobart Welding
Lincoln Mig welder
Welding Links
Chinese Tig Welder
Safety Welding Lawsuits
Welding Safety Tips
OXYFUEL Safety
Welding Curtains
Welding Tips by U
Welding Jobs
More Tips migging cast iron
Gas Welding
Welding Cast Iron
Mig Stainless
Welding Galvanized
Laser Welding
underwater welding
mig techniques
Plasma Cutting
Motorsports Welding
More Welding Tips
 TIG TIPS
more tig tips
even more tig tips
WeldingTest Q&A
WyoTech
MIG Q & A
TIG Welding Q&A
Site Map
Weld like a Girl
Miller Welding Table
privacy policy
WeldTec Torches
weld razor blades
Brazing
How to Mig Weld
Miller Helmet
Welding Pictures
Welding Techniques
ARC welding videos
Welding Aluminum
TIG Videos
Pipe rooting in 6010
by Scott
(Suffolk, VA)
Jody, I've read through lots of your articles, and have sat for hours to watch your videos, but haven't seen any mention of pushing in 6010 on a root pass for pipe. The way I was taught to stick weld pipe was instead of whipping a 6010 rod forward and back, like you would do on structural members, turn the heat down a little and push it into the root. For instance, 4" carbon, Sch. 40, the land is ground to a knife edge, and the gap is 3/32". With the machine set at about 85-90 amps, you push a 1/8" 6010 rod into the root, uphill progression, until you hear a roaring coming from inside the pipe, and all of the sparks and arc disappear into the pipe. There is a tiny keyhole behind the rod and the puddle fills right in behind it. If done right, you can actually take your shield off and not get flashed. It lays a bead about 1/16" to 1/8" high inside, like a stack of dimes, but doesn't fill much on the outside. Depending on the test administrator, you either run a straight bead hot pass and stringer cap, or a fill/ cap single pass weave, (both with a 3/32" 7018, no heat change). Did I miss one of your videos?
Scott, no you didnt miss anything..
I dont have a single video on root pass with 6010
This is another video on a very long to do list.
But Thanks very much for the post, I can picture it well from your description.
Click here to post comments.
Simply click here to return to Stick welding
