XML RSSSubscribe To This Site
XML RSS
Add to Google
Add to My Yahoo!
Add to My MSN
Subscribe with Bloglines
Home
General Welding Topics Latest & Greatest
Forum
Welding Certification
Welding DVD sale
TigFinger Heatshield
Welder Shortage
contact us
Welding Schools
Amazin Blaze
T Shirts
types of welding
Start a Welding Biz
Welding Test Q&A
Tig Welding TIG welding test
Tig Articles
Tig Welding Pipe
Tig Basics Course
Advanced Tig Tips
Tig Aluminum Drill
Tig Settings
Pulse Tig
TIG Weld Aluminum
Welding 4130
Welding Stainless
TIG  Welding
Welding Titanium
Tungsten Sharpeners
Tig Noobs click here
Tig Supplies
Mig Welding Mig Welding tips
Uphill Mig
 MIG Procedures
MIG Supplies
Mig Videos
20 Best Mig Tips
3g welding test 2
Stick Welding
Arc Welding project
Videos Video Archives
Scratch Start Tig
welding video links
TIG Videos
Welding Videos
Welding Table
Miller Welding
 Q&A
welding steel
Welding Hats
Welding DVDs
Reviews lincoln power mig
hobart trek 180
Hobart 115v mig
Everlast Welders
plasma cutter review
How Not to weld
Auto Dark Helmets
Hobart Welding
Lincoln Mig welder
Welding Links
Chinese Tig Welder
Safety Welding Lawsuits
Welding Safety Tips
OXYFUEL Safety
Welding Curtains
Welding Tips by U
Welding Jobs
More Tips migging cast iron
Gas Welding
Welding Cast Iron
Mig Stainless
Welding Galvanized
Laser Welding
underwater welding
mig techniques
Plasma Cutting
Motorsports Welding
More Welding Tips
 TIG TIPS
more tig tips
even more tig tips
WeldingTest Q&A
WyoTech
MIG Q & A
TIG Welding Q&A
Site Map
Weld like a Girl
Miller Welding Table
privacy policy
WeldTec Torches
weld razor blades
Brazing
How to Mig Weld
Miller Helmet
Welding Pictures
Welding Techniques
ARC welding videos
Welding Aluminum
Plasma Cutter Review - Everlast PowerPro 256 combo unit
see the miller plasma cutter video
welding t shirt
Check out the Down and Dirty Welding T Shirt
Today, Sept 2, 2010 I am wrapping up my plasma cutter review because I am tired of farting around.
Just to refresh your memory, The Everlast PowerPro 256 combo welder is an AC DC tig , stick, and plasma-cutter.
If you have not seen the first 3 videos on the everlast powerpro256 yet , you can get to them here...
multiprocess welder PowerPro256 part 1
combo tig welder review PowerPro256 part 2
combo welder review PowerPro256 part 3
The first tests were on DC welding of steel. I was welding on some of the those sewer crawlers and welding stainless steel to carbon steel with er312 ss filler rod.
The arc was smooth as silk.
In fact, I showed some welding done with a Miller Dynasty 200 dx compared to welds that were done with the Everlast powerpro 256 combo welder and you would be hard pressed to tell a difference.
Then I ran into some arc start issues on tig welding aluminum.
But after an email and 2 phone calls with Mike the tech support genius....I adjusted the high frequency arc gap and all was well .
I demonstrated the arc starts by using a tig welding technique called bumping. It is used a lot on clear anodized tubing for marine applications like tuna towers and hand rails for yachts.
but i still needed to test the plasma cutting.
So I was waiting on my machinist friend for a job he promised cutting holes in some 3/4 inch stainless.
But Sometimes waiting on a machinist is like waiting for grass to grow....sloooooowwwww....
So I decided to go ahead and try out the plasma cutting function on some random metals.
• First, I just cut some .063" aluminum sheet. I set the machine on about 30 amps and the air pressure was a constant 60 psi.
slick as a whistle...lickety split.
• Then I cut some 1/4" aluminum on about 50 amps. no problem.
• Then I put a chamfer on some 1/4" steel...perfect.
• Then I chamfered some 1" steel plate...thats pushing the limits.
But the high frequency arc start was true and the PowerPro 256 cut everything I threw at it.
A plasma cutter is a really useful tool for cutting sheet metal as well things a cutting torch just cant cut.
• Carbon steel
• stainless steel,
• nickel alloys,
• aluminum,
• magnesium,
• titanium,
• cobalt,
• copper,
• and cast iron
can all be cut with a plasma cutter.
A plasma cutter does not care what kind of metal it cuts. If it conducts, a plasma cutter will cut it...there are even videos of a plasma-cutter cutting a peanut butter and jelly sandwich.
The Everlast PowerPro 256 combo unit proved itself to be a good plasma cutter. It also tig welds steel and aluminum like a monster.
I am officially impressed. exit plasma cutter page and see welding t shirts
