XML RSSSubscribe To This Site
XML RSS
Add to Google
Add to My Yahoo!
Add to My MSN
Subscribe with Bloglines
Home
General Welding Topics Recent Updates
_forum
Welding Certification
Welding DVD sale
TigFinger Heatshield
Welder Shortage
contact us
Welding Schools
Amazin Blaze
T Shirts
types of welding
Start a Welding Biz
Welding Test Q&A
Tig Welding TIG welding test
Tig Articles
Tig Welding Pipe
Tig Basics Course
Advanced Tig Tips
Tig Aluminum Drill
Tig Settings
Pulse Tig
TIG Weld Aluminum
Welding 4130
Welding Stainless
TIG  Welding
Welding Titanium
Tungsten Sharpeners
Tig Noobs click here
Tig Supplies
Mig Welding Mig Welding tips
Uphill Mig
 MIG Procedures
MIG Supplies
Mig Videos
20 Best Mig Tips
3g welding test 2
Stick Welding
Arc Welding project
Videos Video Archives
Scratch Start Tig
welding video links
Welding Videos
Welding Table
Miller Welding
 Q&A
welding steel
Welding Hats
Welding DVDs
Reviews lincoln power mig
hobart trek 180
Hobart 115v mig
Everlast Welders
plasma cutter review
How Not to weld
Auto Dark Helmets
Hobart Welding
Lincoln Mig welder
Welding Links
Chinese Tig Welder
Safety Welding Lawsuits
Welding Safety Tips
OXYFUEL Safety
Welding Curtains
Welding Tips by U
Welding Jobs
More Tips migging cast iron
Gas Welding
Welding Cast Iron
Mig Stainless
Welding Galvanized
Laser Welding
underwater welding
mig techniques
Plasma Cutting
Motorsports Welding
More Welding Tips
 TIG TIPS
more tig tips
even more tig tips
WeldingTest Q&A
WyoTech
MIG Q & A
TIG Welding Q&A
Site Map
Weld like a Girl
Miller Welding Table
privacy policy
WeldTec Torches
weld razor blades
Brazing
How to Mig Weld
Miller Helmet
Welding Pictures
Welding Techniques
ARC welding videos
Welding Aluminum
TIG Videos
Comments for
position and angles for noobs?
Jan 12, 2010
Tig Welding / Professional Style
by: "WELDOR DON"
Dwayne, Go to your local welding supply & purchase a #10 or # 12, actually try to get each if you can afford, a#6,7,8- thru 12 gas lens and gas lens cups. Use a 3/32" 2% thoriated tungsten if your welding on carbon or stainless material. This tungsten won't work on aluminum, thats a chapter for another time !!!!! If you are buying the argon ask for a 85 - 15 mix and set your CFM's @ about 20 to 30. If the job or school is buying set the CFM's @ 30 to 45. Take your tungsten and put it about 1/8" past the end of the gas cup.Pick your own angle that works for you. No two people weld alike. Adjust your heat accordingly up or down and adjust your tungsten in or out accordingly. Then if your still getting undercut, turn your machine up and add more wire. If your too cold you will cold lap-turn heat up or if your too hot you will undercut. There is a procedure call "Walking the cup" you will need to learn. I don't know how to explain it, but it is the same way you would move a refrigerator by yourself. See if this helps you and good luck @ practice, practice. I've 65 and been welding for 47 yrs. and still learning.www.perform53.com or perform53@gmail.com Skip
Simply click here to return to tig forum
Return to position and angles for noobs?
