listen to me for one when it comes to 232 no on runs 120 wire speed if you do quickly go dig a hole and jump in it and hide cause your a disgrace to the trade for two depending on how much lead you have out try 180 wire at 23.9 or if your right out of the box try 23 if you have a steel backer bar if not get your self a piece of copper or brass then on the vert out of the box22 160 100ft 23 165 and stick and move stick and move as fast as you say it do it small side to side and up tie it in and your golden clean it and jump up to the 180 settings i run 225 on everything sometimes up to 300 or more but remember babysteps this wire is very tempermental and doesnt stand for fighting it it loves heat so last but not least trust it and it will never let you down thanx oh by the way i run 3 spools a day on the average full pins and tubes thanx
