XML RSSSubscribe To This Site
XML RSS
Add to Google
Add to My Yahoo!
Add to My MSN
Subscribe with Bloglines
Home
General Welding Topics Latest & Greatest
Forum
Welding Certification
Welding DVD sale
TigFinger Heatshield
Welder Shortage
contact us
Welding Schools
Amazin Blaze
T Shirts
types of welding
Start a Welding Biz
Welding Test Q&A
Tig Welding TIG welding test
Tig Articles
Tig Welding Pipe
Tig Basics Course
Advanced Tig Tips
Tig Aluminum Drill
Tig Settings
Pulse Tig
TIG Weld Aluminum
Welding 4130
Welding Stainless
TIG  Welding
Welding Titanium
Tungsten Sharpeners
Tig Noobs click here
Tig Supplies
Mig Welding Mig Welding tips
Uphill Mig
 MIG Procedures
MIG Supplies
Mig Videos
20 Best Mig Tips
3g welding test 2
Stick Welding
Arc Welding project
Videos Video Archives
Scratch Start Tig
welding video links
TIG Videos
Welding Videos
Welding Table
Miller Welding
 Q&A
welding steel
Welding Hats
Welding DVDs
Reviews lincoln power mig
hobart trek 180
Hobart 115v mig
Everlast Welders
plasma cutter review
How Not to weld
Auto Dark Helmets
Hobart Welding
Lincoln Mig welder
Welding Links
Chinese Tig Welder
Safety Welding Lawsuits
Welding Safety Tips
OXYFUEL Safety
Welding Curtains
Welding Tips by U
Welding Jobs
More Tips migging cast iron
Gas Welding
Welding Cast Iron
Mig Stainless
Welding Galvanized
Laser Welding
underwater welding
mig techniques
Plasma Cutting
Motorsports Welding
More Welding Tips
 TIG TIPS
more tig tips
even more tig tips
WeldingTest Q&A
WyoTech
MIG Q & A
TIG Welding Q&A
Site Map
Weld like a Girl
Miller Welding Table
privacy policy
WeldTec Torches
weld razor blades
Brazing
How to Mig Weld
Miller Helmet
Welding Pictures
Welding Techniques
ARC welding videos
Welding Aluminum
Comments for
thick aluminum
Feb 24, 2010
fatluminum blues
by: mike c.
Jody, thanks for the info this is a multi stage project for a local machine shop i had to tack weld these two split rings together on the inside so they could be chucked up on a four jaw lathe for further machining so that weld will be machined off when they turn the part too the inside spec when they get all that done i have to weld two blocks on the outside of each half .0240 from the end w/ a 3/16 bead! should be interesting. i ended up using a 75% he 25% argon mix and 2% thoriated tungsten 3/32 didnt have much luck with the ceriated with that much heat i may have had the gas wrong i donno but the final welds on these parts have to be run through every test imaginable so i'd better get my stuff strait. . thanks again for your help and quick reply.
mike c.
Simply click here to return to tig forum
Return to thick aluminum
