XML RSSSubscribe To This Site
XML RSS
Add to Google
Add to My Yahoo!
Add to My MSN
Subscribe with Bloglines
Home
General Welding Topics Latest & Greatest
Forum
Welding Certification
Welding DVD sale
TigFinger Heatshield
Welder Shortage
contact us
Welding Schools
Amazin Blaze
T Shirts
types of welding
Start a Welding Biz
Welding Test Q&A
Tig Welding TIG welding test
Tig Articles
Tig Welding Pipe
Tig Basics Course
Advanced Tig Tips
Tig Aluminum Drill
Tig Settings
Pulse Tig
TIG Weld Aluminum
Welding 4130
Welding Stainless
TIG  Welding
Welding Titanium
Tungsten Sharpeners
Tig Noobs click here
Tig Supplies
Mig Welding Mig Welding tips
Uphill Mig
 MIG Procedures
MIG Supplies
Mig Videos
20 Best Mig Tips
3g welding test 2
Stick Welding
Arc Welding project
Videos Video Archives
Scratch Start Tig
welding video links
TIG Videos
Welding Videos
Welding Table
Miller Welding
 Q&A
welding steel
Welding Hats
Welding DVDs
Reviews lincoln power mig
hobart trek 180
Hobart 115v mig
Everlast Welders
plasma cutter review
How Not to weld
Auto Dark Helmets
Hobart Welding
Lincoln Mig welder
Welding Links
Chinese Tig Welder
Safety Welding Lawsuits
Welding Safety Tips
OXYFUEL Safety
Welding Curtains
Welding Tips by U
Welding Jobs
More Tips migging cast iron
Gas Welding
Welding Cast Iron
Mig Stainless
Welding Galvanized
Laser Welding
underwater welding
mig techniques
Plasma Cutting
Motorsports Welding
More Welding Tips
 TIG TIPS
more tig tips
even more tig tips
WeldingTest Q&A
WyoTech
MIG Q & A
TIG Welding Q&A
Site Map
Weld like a Girl
Miller Welding Table
privacy policy
WeldTec Torches
weld razor blades
Brazing
How to Mig Weld
Miller Helmet
Welding Pictures
Welding Techniques
ARC welding videos
Welding Aluminum
Tig Welding stainless steel video Review
Tig Welding stainless steel sailboat parts - a video review
In this Tig welding stainless steel video, a Stainless sailboat part is being fixtured, tacked, and welded. The Guy doing the tig welding has obviously been doing this a while...
this aint his first rodeo.
He pays close attention to getting a good fitup with no gaps and he makes sure his parts are aligned properly before he welds it.
Pay special attention to how he tacks with no filler rod. He does it really quick. That is what works on stainless. If the pieces you are tacking are fit up correctly tight with no gap, you can use a quick blast of amperage of about 1 amp for every one thousands of thickness you are welding. For example, for .063 thick metal, 63 amps will work. So for tacking something like this, set the machine to 63 amps max amperage and then Position the torch right where you want the tack and with the tip of the electrode pretty close, like less than 1/8" and give it full pedal all at once and let off quickly. This works a lot better for tacking stainless steel than lighting up and gradually increasing the amperage.
Another thing to notice is that he pulses the amperage using the foot pedal. For stainless steel, this keeps the heat from building up. It is kind of an advanced technique and is not for rank beginners.
Because he spent the time to get a good fit with no gaps, he does not even need filler rod. He is able to pulse the foot pedal and fuse the metal together in a series of overlapping puddles without needing extra filler metal.
A lot of food service equipment is welded this way. I dont see any purge gas being fed to the back side of this weld. That could be a corrosion problem years down the road with all the salt air and moisture this part will see.
The weld looks really good. A bit out of focus in the camera, but you can tell its a good stainless steel tig weld anyway.
This guy has skills.
leave tig welding stainless steel video page and read more about tig welding
