XML RSSSubscribe To This Site
XML RSS
Add to Google
Add to My Yahoo!
Add to My MSN
Subscribe with Bloglines
Home
General Welding Topics Latest & Greatest
Forum
Welding Certification
Welding DVD sale
TigFinger Heatshield
Welder Shortage
contact us
Welding Schools
Amazin Blaze
T Shirts
types of welding
Start a Welding Biz
Welding Test Q&A
Tig Welding TIG welding test
Tig Articles
Tig Welding Pipe
Tig Basics Course
Advanced Tig Tips
Tig Aluminum Drill
Tig Settings
Pulse Tig
TIG Weld Aluminum
Welding 4130
Welding Stainless
TIG  Welding
Welding Titanium
Tungsten Sharpeners
Tig Noobs click here
Tig Supplies
Mig Welding Mig Welding tips
Uphill Mig
 MIG Procedures
MIG Supplies
Mig Videos
20 Best Mig Tips
3g welding test 2
Stick Welding
Arc Welding project
Videos Video Archives
Scratch Start Tig
welding video links
TIG Videos
Welding Videos
Welding Table
Miller Welding
 Q&A
welding steel
Welding Hats
Welding DVDs
Reviews lincoln power mig
hobart trek 180
Hobart 115v mig
Everlast Welders
plasma cutter review
How Not to weld
Auto Dark Helmets
Hobart Welding
Lincoln Mig welder
Welding Links
Chinese Tig Welder
Safety Welding Lawsuits
Welding Safety Tips
OXYFUEL Safety
Welding Curtains
Welding Tips by U
Welding Jobs
More Tips migging cast iron
Gas Welding
Welding Cast Iron
Mig Stainless
Welding Galvanized
Laser Welding
underwater welding
mig techniques
Plasma Cutting
Motorsports Welding
More Welding Tips
 TIG TIPS
more tig tips
even more tig tips
WeldingTest Q&A
WyoTech
MIG Q & A
TIG Welding Q&A
Site Map
Weld like a Girl
Miller Welding Table
privacy policy
WeldTec Torches
weld razor blades
Brazing
How to Mig Weld
Miller Helmet
Welding Pictures
Welding Techniques
ARC welding videos
Welding Aluminum
Welding Video Review - Chopper Gas Tank - Jeff Nickell
Welding Video on,....
How to Tig weld a Chopper gas tank with Jeff Nickell
This Welding video is describing how to tig weld a sheet metal formed gas tank for a custom chopper.Jeff describes the Tig welding process while he welds the bungs in a gas tank that is being built for Fabio's custom chopper. The Chopper is going to have the industrial look and so the welds are not going to be dressed or ground.
All the tig welds will show "as is".
Jeff is using an air cooled #17 Miller Diamondback Air cooled torch. Thats a pretty big torch. I personally love to use the smaller wp9 air cooled torch with gas lens collet body and a #7 cup for work like this.
Tanks like this are typically formed from 18 ga 1010 cold rolled carbon steel. 18ga is only around .050" thick give or take a little. Jeff says he is welding 16 ga steel which is .063" thick. Even with the added thickness of the bungs, this job will take much less than 100 amps.
I would use a 3/32" or even a 1/16" tungsten electrode for this job. Using too large an electrode like a 1/8" will make for rough starts and arc wandering at low amperages. If a 1/8" electrode is all you have, just grind a needle point and a long taper and things will go better on your starts.
Jeff is right about needing different size electrodes for different thickness material. But amperage is the main reason to select electrode size. If you need 100 amps or less, a 1/16" thoriated, ceriated, or lanthanated electrode will be fine and will start better at low amperage than a bigger one.
One reason why shops like this typically use bigger electrodes than what is needed is because its just more convenient to have one size for every job and not to have to change electrodes. That 1/8" electrode Jeff is using is big enough to handle 1/4" aluminum but it is not the best size for thin sheet metal.
Skilled welders like Jeff can compensate for things like this and make it work. I am not trying to be critical, I am just taking the opportunity to point out some tips on electrode selection.
Overall This Welding Video was pretty instructive .
And the design of the bike with bare metal and exposed welds is a really cool idea.
leave welding video page and read more on tig welding
more welding videos
welding videos - Shortage of welders
welding videos - Tig welding small gun parts
welding videos - Tig welding stainless steel
welding videos - tig welding steel
welding videos - chin operated welding helmet
welding videos - pipe welding video
welding videos - gas welding
welding videos - welding contest champion
welding videos - stick welding video
welding videos - tig welding chopper gas tank
welding videos - virtual reality welding training
welding videos - welding training and welding schools
welding videos - tig welding clamps for headers
welding videos - aluminum brazing rods
welding videos - gas tungsten arc welding clips
welding videos - jesse james choppers and welding
welding videos - how not to weld, seriously
welding videos - mig welding
welding videos - tig welding 4130 chromoly
welding videos - tig welding aluminum
welding videos - tig welding aluminum bike frame
welding videos - welder shortage jay leno
welding videos - welding videos reviewed
