Tig Weld Carbon Steel flash tacks 18 ga outside corner settings
scroll down for settings
Did you know?...
*** We have a New TIG course learning system over at welderskills.com designed to help you learn faster, with less frustration, and with less metal.
***And that you will get Free Access to this $99.99 TIG course... included as part of your membership?
***And that if you use promo code LPZ1
you can get 50% off your first month after your Free 7 day  Trial?
***Its Easy to sign up
No Ads, No BS style
METAL TYPE = CARBON STEEL
THICKNESS = 18 GA
WELD TYPE = CORNER FLASH TACKS
JOINT TYPE = CORNER JOINT
POSITION = ALL
AMPERAGE = 90 amps with foot pedal ( pump pedal very quickly or use panel amperage that uses pedal as switch)
FILLER WIRE = NONE
GAS FLOW = 10 CFH argon
CUP SIZE =  5
PRE FLOW = .5 SEC
POST FLOW = 3 SEC
TIPS: prop using cup with very little electrode extension.
rock cup in until tip of tungsten touches metal.
then rock cup back to leave a very small arc gap
pump foot pedal quickly with amperage set to 1.5 thickness being tacked.
practice on scrap if its your first time using flash burst tacks
tig flash tacks
