XML RSSSubscribe To This Site
XML RSS
Add to Google
Add to My Yahoo!
Add to My MSN
Subscribe with Bloglines
Home
General Welding Topics Recent Updates
_forum
Welding Certification
Welding DVD sale
TigFinger Heatshield
Welder Shortage
contact us
Welding Schools
Amazin Blaze
T Shirts
types of welding
Start a Welding Biz
Welding Test Q&A
Tig Welding TIG welding test
Tig Articles
Tig Welding Pipe
Tig Basics Course
Advanced Tig Tips
Tig Aluminum Drill
Tig Settings
Pulse Tig
TIG Weld Aluminum
Welding 4130
Welding Stainless
TIG  Welding
Welding Titanium
Tungsten Sharpeners
Tig Noobs click here
Tig Supplies
Mig Welding Mig Welding tips
Uphill Mig
 MIG Procedures
MIG Supplies
Mig Videos
20 Best Mig Tips
3g welding test 2
Stick Welding
Arc Welding project
Videos Video Archives
Scratch Start Tig
welding video links
Welding Videos
Welding Table
Miller Welding
 Q&A
welding steel
Welding Hats
Welding DVDs
Reviews lincoln power mig
hobart trek 180
Hobart 115v mig
Everlast Welders
plasma cutter review
How Not to weld
Auto Dark Helmets
Hobart Welding
Lincoln Mig welder
Welding Links
Chinese Tig Welder
Safety Welding Lawsuits
Welding Safety Tips
OXYFUEL Safety
Welding Curtains
Welding Tips by U
Welding Jobs
More Tips migging cast iron
Gas Welding
Welding Cast Iron
Mig Stainless
Welding Galvanized
Laser Welding
underwater welding
mig techniques
Plasma Cutting
Motorsports Welding
More Welding Tips
 TIG TIPS
more tig tips
even more tig tips
WeldingTest Q&A
WyoTech
MIG Q & A
TIG Welding Q&A
Site Map
Weld like a Girl
Miller Welding Table
privacy policy
WeldTec Torches
weld razor blades
Brazing
How to Mig Weld
Miller Helmet
Welding Pictures
Welding Techniques
ARC welding videos
Welding Aluminum
TIG Videos
Good dual voltage, absolutely unbelievably awesome scratch tig/stick welder for the price,,,
by Lee Abel
(Loogootee, IN)
As for me I really was looking for a good TIG welder but came across dual use TIG/Stick units, several from Chinese companies with questionable reputations and of course some from the big names.
WELL, I picked up a Thermal Arc 95S Inverter TIG/Stick welder back when my taxes came back.
Well I did have an issue on the second time I fired it up to "play" the on/off switch wouldn't shut off.
Well crud, maybe what less than a month old and already issues, it welded great. So I called Thermal Arc, I offered to just take a switch figuring they would send it to me.
Well took it back to welding supply store, they called, Thermal Arc wanted this one back, then we proceed to get some info on the 95S, in the first 5000 (this is after getting serial number off mine), they had(till mine) only had 12 failures/defects/damage in first 5000 (sold) and over half were from shipping damage, this meant mine was like #13 with an issue. I gave it up on friday and had my new one by following Thursday!
NOW THATS SERVICE!
And according to the fella from Thermal Arc they had sold many more than 5000(I heard somewhere over 20k).
I really believe this unit, if it had some AC and frequency controls would be a game changer.
I just finished welding up the 50+ yr old mover deck on my Snapper mower. Ground rust off the deck, ground rust off the patch material steel.
Well after its all done I had to clearance around the metal loop(like 1/2 rod) built on side of the deck
So there is a nickel size or bigger hole around this rod that still needs filled in.
Well I was going to try and build it up with the TIG, but it was getting too hot.
Well I really needed to get to mowing so I just decide to whip out one of the 4 6013 welding rods that came with it.
Now the available amps that could be dialed in on 110 is much less than on scratch TIG mode. Well I set it to the max and swap cables and fire up.
3 t o4 seconds later its all welded up! Done. ready to mow,well till other issues came up but that had nothing to do with welding.
If you guys want a ballsy kick butt TIG/Stick welder,,backed by probably one of the best companies out there, take a strong hard look at Thermal Arc 95S.
Even if you just buy it as a DC stick kit then buy the parts later to jump to TIG work and this unit will not bump a 20 amp breaker ON AN EXTENSION CORD.
My Astro Mig welder doesnt like extension cords and its 110 only.
Remember this Thermal Arc 95S. its a great unit!
Click here to post comments.
Simply click here to return to Stick welding
