by Bobby
(ocala,fl)
on the 6g pipe test everyone has a weak side or a more difficult side to weld, if facing the pipe mine is the 6-3o'clock,an easy fix is take your file put it in the top of the pipe so it lays horizontal then you can rest your elbow on the file which allows you to be a lot more steady.
Simply click here to return to Stick welding.
