A good starting point for setting your amperage for stick welding is the amperage setting should be roughly the same as the decimal equivalent of the diameter of the rod.
ie 3/32-90 amps 1/8-125 amps 5/32-155amps. This works for 7018 and most rods. 6011 runs at a little lower amperage. you might have to go colder(lower amps) for thinner materials or hotter for thicker materials.
Comments for
Join in and write your own page! It's easy to do. How? |
