Tip for welding horizontal lap joint 6010 rod
by homer
(waycross ga usa)
what you need to do is tack your weld. Once you have it tacked then you want to have a 90 degree angle on the weld with a zero degree travel angle and just let the rod burn. No weave. if you do it right then you will produce a beautiful fucking weld every time
