To stop porosity
by ryan
(australia)
To stop porosity it usually depends on the angle of the rod.
I always start it off at nearly an exact 5 degrees.
If your pipe welding to a stringent standard the last thing You wanna do is start arc it at a distance from where you finished,all this will do is give you more concern about what you just put down.
Like i said best way is to adjust your angle.
