Vertical Stick Welding
by Bryan Miller
(Dallas, TX)
Jody- I used to think I was a decent welding with stick- if its flat I can make beautiful weld- but turn a bead vertical and all I get is globs of metal all over the place. Any tips for vertical stick welding?
here are a few tips that usually help a lot
set machine just hot enough that when you hold a very tight arc , it wont stick
shoot for a dead nuts 90 degree stick angle or a slight push
if weaving, pause at toes, and go across the middle pretty quick
Return to Stick welding.
