welding thick metals
i have a lincoln 115v flux core mig that says it can handle metal thicknesses of 1/8in. the problem is i need to weld some 1/4in steel to .083in wall square tubing. how should i go about doing this? maybe put in a v groove and fill that in with a bead then put on a second bead on the 1/4 inch thick steel side of the original weld? im new to welding so this is just a guess.
First of all, if this is a critical weld, you might want to get a more powerful machine.
but a few ways to get the most out of your 115 volt mig are...
position the piece so that you are welding uphill or at least at a 45 degree angle uphill.
preheat with a small propane torch.
clean the metal and or grind a v groove.
plug into a strong 20 amp circuit and do not use an extension cord
good luck
Return to Contact Us.
