I made my first video in 2008 and now and there are well over 500 welding videos on this website.
Along the way, I started an online store to help support my video efforts.
I feel very fortunate because that has turned into a family business that lets me support my family.
So now, I am gradually adding new products to my store at weldmonger.com
But only after I have tried them out.
I would like to tell you about a few new weldmonger products I have added to my store at weldmonger.com
One of the most recent product on the store is a TIG Pro Kit
pictured below is the TIG pro Kit for 9 and 20 style torches
I also have the 17 , 18, 26 version pictured below
The Hel in Hel-hook is short for Helmet.
and the Hel-hook lets you hang your welding helmet, a wrench, a purge hose, and other stuff on your gas cylinder...very handy.
I have added both the steel diy kit and the molded plastic version to the store.
The steel version is 3/16” thick steel and only takes about 5 minutes or less to weld together.
I used silicon bronze for mine because it is just such an easy way to join pieces like this that have a tab and slot design.
Then there is the magtab jumbo.
I have been using the small magtab for several years and have found it to be super useful for not only welding tabs on tubing, but for end caps and other things.
The Jumbo version has much stronger magnets and holds bigger parts.
Its every bit as handy as the regular size magtab and holds bigger and heavier parts. I have found all sorts of uses for both the small magtab and jumbo versions. Especially on outside corner joints for boxes and tanks.
Another new product is this affordable dual flowmeter . If you weld stainless steel, you need a dual flowmeter. Sanitary stainless tubing, food service stainless of any kind, stainless pipe, as well as inconel exhaust collectors and titanium parts require an argon purge to the back side in order to preserve the properties of the metal.
The easiest way to purge is with a dual flowmeter
Furick cups have been on the store for a while now but are still a very popular item for welding stainless, nickel alloys, and titanium. I really like the Furick #8 pro for general welding of all types of materials including aluminum because it offers a great shielding area and also really helps me see better by acting as a flood light.
The Furick #12 is a great all around cup for 4130 chromoly and stainless.
I really like the ceramic version Furick cups too. they are much more durable than the clear cups and shield  just as well.
So I would recommend the ceramic 12 over the clear 12 for most folks.
For titanium, the BBW cup really does the trick. The clear version is great when you need to look thru the cup, but the ceramic version is tougher and works great.
