Accessory Kit-TIG Welding Consumables
The great thing about a kit of tig cups and consumables is that you can be sure all the parts will fit your torch.
When you start shopping around for individual part numbers it is easy to get confused.
Did you know a 13N28 is a 3/32" collet body for a 20 style tig torch?
I had to go look it up myself to be sure.
Nothing about 13N28 indicates what it is.   TIG consumables have crazy part numbers.  A 3/32" gas lens collet body for the same 20 style torch is a 45v44.
So instead of trying to make your own kit. We do all the work for you and make sure all the collets, collet bodys, cups, and end caps fit your TIG torch.
All you need to do is make sure what type of tig torch you have.
This Video Shows Tips and Techniques for How to TIG Weld Carbon Steel, Stainless, Aluminum, and Titanium
9 20 tig torch collet bodies
