MIG Welding 11ga Steel Corner joint Flat position
Mig welding 11ga corner joint settings and techniques and all the tips you need to be successful.
It doesn't matter what the part is, if it is made from 11ga steel and its a corner joint in the flat position, then this page and video are for you.
Settings used for this Corner joint weld
THICKNESS = 11ga .125"
WELD TYPE = Fillet weld
JOINT TYPE = CORNER
POSITION = 1F, FLAT
VOLTS = 18.1 volts
WIRE SPEED = 149 IPM
WIRE SIZE = .035"
GAS FLOW = 20-25 CFH C25 GAS
CTWD  = 3/8”-1/2"
FILLER METAL = ER70S6
ADDITIONAL SETTINGS = TIPS:A relatively short stickout aka contact to work distance CTWD of 3/8” to 1/2" makes a big difference.
