Mig Welding Aluminum 1/2"  thick vertical uphill settings technique
primeweld mig180
I think of my Mig180 mostly as a Great Little MIG Welder with a great arc and nice small mig gun that feels great in my hand... but it also Stick welds, and even comes with a spool gun for aluminum.
just look at all that comes with it... That is a lot of bang for the buck!
primeweld mig 180 stuff
mig-180-primeweld-settings-techniques-2f-3f-thumb
115-volt-mig-1f-flat-corner-thumb
basics-3f-downhill-11ga-mig180-thumb
scroll down for settings for Vertical mig aluminum
WELD PROCESS = GMAW, GAS METAL ARC WELDING
METAL TYPE = ALUMINUM ALLOY
THICKNESS = 1/4" INCH TO 1/2"
WELD TYPE = Fillet
JOINT TYPE = TEE
POSITION = 3F VERTICAL UPHILL
VOLTS = 25.0 volts
WIRE SPEED = 590  IPM
WIRE SIZE = .035” 4043
GAS FLOW = 25-35 CFH 100% ARGON GAS
CTWD  = 1/2” - 3/4"
FILLER METAL = ER4043 .035"
TIPS:A longer contact to work distance CTWD of 1/2”-3/4” helps with spray transfer aluminum mig welding.
