MIG WELDING CARBON STEEL 11 GA .030" WIRE 2F TEE
19 VOLTS 250 IPM .030”
THICKNESS = 11GA
WELD TYPE = Fillet weld
JOINT TYPE = TEE
POSITION = 2F HORIZONTAL
VOLTS = 19.0 volts
WIRE SPEED = 250 IPM
WIRE SIZE = .030"
AMPS =
GAS FLOW = 20-25 CFH C25 GAS
CTWD  = 3/8”-1/2"
TUNGSTEN  =
FILLER METAL = ER70S6
The technique shown is a series of cursive e’s to  keep the arc toward the leading edge of the puddle
