Mig Welding Carbon Steel pipe 5g downhill root pass
scroll down for settings for 5g pipe mig root
THICKNESS = 3/8"
WELD TYPE = groove
JOINT TYPE =open butt
POSITION = 5G pipe weld downhill root
VOLTS = 18 volts
WIRE SPEED = 210 IPM
WIRE SIZE = .035"
GAS FLOW = 20-25 CFH C25 GAS
CTWD  = 3/8”-1/2"
FILLER METAL = ER70S6 .035"
The technique shown is a very slight side to side motion while keeping the arc on the front edge of the puddle while not far enough to shoot wire thru the gap.
