STICK WELDING CARBON STEEL 3/8" THICKNESS 5/32" 7018 STRINGERs
scroll down for settings for 5/32" 7018 vertical uphill tee joint 3F stringer beads
METAL TYPE = CARBON STEEL A36
THICKNESS = 3/8"
WELD TYPE = Fillet weld MULTI PASS
JOINT TYPE = TEE
POSITION = 3F VERTICAL UP
AMPS = 140 AMPS
ELECTRODE = 7018 5/32"
TIPS:SET THE AMPERAGE JUST HOT ENOUGH TO NOT STICK THE ROD WHEN YOU HOLD A TIGHT ARC…THEN HOLD A TIGHT ARC.
ANY SUCCESSFUL DEMONSTRATION DISPLAYING AMPERAGE SHOULD GET YOU IN THE BALL PARK.
