STICK WELDING CARBON STEEL 1/4" THICK 3F TEE 1/8" 7018 WEAVE
For Structural Welding done to code specifications like AWS D1.1 , stringer beads are often required. But certain jobs still allow for weaving and this 3f vertical tee joint is also a good way to practice for pipe.
METAL TYPE = CARBON STEEL
THICKNESS = 1/4"
WELD TYPE = Fillet weld WEAVE SECOND PASS
JOINT TYPE = TEE
POSITION = 3f vertical uphill
AMPS = 125 AMPS
ELECTRODE = 7018 1/8"
DIFFERENT MANUFACTURERS ELECTRODES REQUIRE SLIGHTLY DIFFERENT AMPERAGE SETTINGS.ANY SUCCESSFUL DEMONSTRATION DISPLAYING AMPERAGE SHOULD GET YOU IN THE BALL PARK.
