STICK CARBON STEEL, 3G DOWNHILL PLATE COVER PASS 5/32" 7010
this is a practice plate in preparation for welding pipe
7010 5/32" COVER PASS SETTINGS
METAL TYPE = CARBON STEEL
THICKNESS = 3/8"
WELD TYPE = GROOVE WELD  COVER PASS
JOINT TYPE = BUTT
POSITION = 3G DOWNHILL PLATE
AMPS = 135 AMPS
ELECTRODE = 7010  5/32"
ANY SUCCESSFUL DEMONSTRATION DISPLAYING AMPERAGE SHOULD GET YOU IN THE BALL PARK.TWEAK AMPS FROM THAT POINT AND ADJUST ARC CONTROL TO FIT THE SITUATION
