METAL TYPE = CARBON STEEL
THICKNESS = 3/8"
WELD TYPE = GROOVE WELD 22.5 DEGREE BEVELS 2 STRINGER BEAD CAP
JOINT TYPE = OPEN BUTT 1/4” GAP 1/4” BACKING BAR
POSITION = 3G
AMPS = 130 AMPS
ELECTRODE = 7018 5/32"
ADDITIONAL SETTINGS =ARC FORCE SET 7-10 TO PREVENT STICKING AT 130 AMPSTIPS:
SET THE AMPERAGE HOT ENOUGH TO NOT STICK THE ROD WHEN YOU HOLD A TIGHT ARC…THEN HOLD A TIGHT ARC.
