Stick Welding 1/4" Carbon Steel 6011 1/8" 3F tee  vertical uphill
looking for an affordable high quality auto dark welding helmet?
click on pic below to learn more
ARCONE 1000F-0100
scroll down for settings
METAL TYPE = CARBON STEEL
THICKNESS = 1/4"
WELD TYPE = FILLET
JOINT TYPE = TEE
POSITION =3F  VERTICAL UPHIL
LAMPS = 80-85 AMPS
ELECTRODE = 6011 1/8"
ADDITIONAL SETTINGS =  DIG/ARC CONTROL SET TO 7
TIPS: WHIP AND PAUSE MOTION USED TO CONTROL HEAT
