Stick Welding 1/4" carbon steel bumper 7014 1/8"
7014 is a good choice for when the metal thickness is 3/16" or thicker and when a larger weld is needed
looking for a high quality affordable auto dark helmet?  click on helmet to learn more
ARCONE 1000F-0100
scroll down for settings
METAL TYPE = CARBON STEEL
THICKNESS = 1/4"
WELD TYPE = FILLET
JOINT TYPE = TEE
POSITION = 2F
AMPS = 150 AMPS
POLARITY = AC on a lincoln tombstone buzz box
ELECTRODE = 7014 1/8"
TIPS: DIFFERENT MANUFACTURERS ELECTRODES REQUIRE SLIGHTLY DIFFERENT AMPERAGE SETTINGS.
TWEAK AMPS AND ADJUST ARC CONTROL TO FIT THE SITUATION
