STICK WELDING CARBON STEEL 3/8" PLATE DOWNHILL ROOT 5/32" 7010
scroll down for settings
METAL TYPE = CARBON STEEL
THICKNESS = 3/8"
WELD TYPE = GROOVE WELD  ROOT PASS 1/16 GAP, 1/16 LAND
JOINT TYPE = BUTT
POSITION = 45 DEGREE DOWNHILL PLATE
AMPS = 126 AMPS
ELECTRODE = 7010 5/32"
TIPS:  DIFFERENT MANUFACTURERS ELECTRODES REQUIRE SLIGHTLY DIFFERENT AMPERAGE SETTINGS.
 AMPERAGE shown SHOULD GET YOU IN THE BALL PARK.
