Whether you are a student, hobbyist, or a working welder who wants to sharpen up, you can take a free trial and even get 25% off your first 3 months with promo code QS25.
6G 6 INCH 7018 CAP ANDREW WS END.mov
METAL TYPE = CARBON STEEL 6 INCH SCHED 80 PIPE
THICKNESS = .430” WALL THICKNESS
WELD TYPE = GROOVE
JOINT TYPE = BUTT
POSITION = 6G PIPE TEST uphill
AMPS = 115 AMPS
ELECTRODE = 7018 1/8"
TIPS: DIFFERENT MANUFACTURERS ELECTRODES REQUIRE SLIGHTLY DIFFERENT AMPERAGE SETTINGS.ANY SUCCESSFUL DEMONSTRATION DISPLAYING AMPERAGE SHOULD GET YOU IN THE BALL PARK.TWEAK AMPS FROM THAT POINT AND ADJUST ARC CONTROL TO FIT THE SITUATION
