STICK WELDING CARBON STEEL PIPE 6 INCH SCHEDULE 80 6g 7018 1/8" hot pass
scroll down for settings
METAL TYPE = CARBON STEEL 6 INCH SCHED 80 PIPE
THICKNESS = .430” WALL THICKNESS
WELD TYPE = GROOVE HOT PASS
JOINT TYPE = BUTT
POSITION = 6G PIPE TEST uphill
AMPS = 105 AMPS FOR HOT PASS
ELECTRODE = 7018 1/8"
TIPS: DIFFERENT MANUFACTURERS ELECTRODES REQUIRE SLIGHTLY DIFFERENT AMPERAGE SETTINGS.ANY SUCCESSFUL DEMONSTRATION DISPLAYING AMPERAGE SHOULD GET YOU IN THE BALL PARK.TWEAK AMPS FROM THAT POINT AND ADJUST ARC CONTROL TO FIT THE SITUATION
var l = window.location.href,
d = document;
