Whether you are a student, hobbyist, or a working welder who wants to sharpen up, you can take a free trial and even get 25% off your first 3 months with promo code QS25.
METAL TYPE = CARBON STEEL
THICKNESS = 3/8"
WELD TYPE = GROOVE WELD 22.5 DEGREE BEVELS ROOT PASS
JOINT TYPE = OPEN BUTT 1/4” GAP 1/4” BACKING BAR
POSITION = 3G
AMPS = 130 AMPS
ELECTRODE = 7018 5/32"
ADDITIONAL SETTINGS = ARC FORCE SET TO 10 TO PREVENT STICKING AT 130 AMPS
TIPS:
