STICK WELDING CARBON STEEL 3/8" PLATE 5/32" 7010
scroll down for settings for hot pass using 5/32" 7010
METAL TYPE = CARBON STEEL
THICKNESS = 3/8"
WELD TYPE = GROOVE WELD  HOT PASS OVER GROUND ROOT
JOINT TYPE = BUTT
POSITION = 3G DOWNHILL PLATE
AMPS = 135 AMPS
ELECTRODE = 7010  5/32"
ADDITIONAL SETTINGS =   DIFFERENT MANUFACTURERS ELECTRODES REQUIRE SLIGHTLY DIFFERENT AMPERAGE SETTINGS.ANY SUCCESSFUL DEMONSTRATION DISPLAYING AMPERAGE SHOULD GET YOU IN THE BALL PARK.TWEAK AMPS FROM THAT POINT AND ADJUST ARC CONTROL TO FIT THE SITUATION
