STICK WELDING CARBON STEEL 3/8" PLATE DOWNHILL 5/32" xx10 root
scroll down for settings
METAL TYPE = CARBON STEEL
THICKNESS = 3/8” WALL 12 INCH PIPE
WELD TYPE = 12 INCH PIPE DOWNHILL ROOT PASS 3/32" GAP, 3/32" LAND
JOINT TYPE = BUTT
POSITION = 5G DOWNHILL
AMPS = 126-132 AMPS
ELECTRODE = 7010 5/32"
TIPS:  DIFFERENT MANUFACTURERS ELECTRODES REQUIRE SLIGHTLY DIFFERENT AMPERAGE SETTINGS.ANY SUCCESSFUL DEMONSTRATION DISPLAYIN
G AMPERAGE SHOULD GET YOU IN THE BALL PARK.TWEAK AMPS FROM THAT POINT AND ADJUST ARC CONTROL TO FIT THE SITUATION
xx10 downhill root plate test
