Stick Welding 3/8" plate Downhill hot pass 3/16" 7010 settings
scroll down for settings
METAL TYPE = CARBON STEEL
THICKNESS = 3/8"
WELD TYPE = GROOVE WELD  HOT PASS  OVER 5/32” 7010 ROOT
JOINT TYPE = BUTT
POSITION = 3G HYBRID  DOWNHILL PLATE
AMPS = 145-150 AMPS
ELECTRODE = 7010  3/16"
stick welding downhill
