METAL TYPE = CARBON STEEL
THICKNESS = 3/8"
WELD TYPE = GROOVE OPEN ROOT 30 DEG BEVELS 3/32” GAP 1/16” LAND
JOINT TYPE = BUTT
POSITION = HYBRID VERTICAL OVERHEAD AT 45 DEG FOR PRACTICE
AMPS = 70 AMPS
ELECTRODE = 7016 3/32"
TIPS: SOME PROCEDURES CALL FOR DCEN WITH 7016 WHICH MIGHT ACTUALLY WORK BETTER BUT REGARDLESS WHICH POLARITY WORKS BETTER, FOLLOW THE PROCEDURE
DIFFERENT MANUFACTURERS ELECTRODES REQUIRE SLIGHTLY DIFFERENT AMPERAGE SETTINGS.ANY SUCCESSFUL DEMONSTRATION DISPLAYING AMPERAGE SHOULD GET YOU IN THE BALL PARK.
