Stick Welding Carbon Steel Pipe root with 7016 3/32"
scroll down for settings for 7016 3/32" root pass
METAL TYPE = CARBON STEEL PIPE 12 INCH 30 DEG BEVELS
THICKNESS = 3/8"
WELD TYPE = GROOVE OPEN ROOT 30 DEG BEVELS 3/32” GAP 1/16” LAND
JOINT TYPE = BUTT
POSITION = 5G UPHILL
AMPS = 70 AMPS
ELECTRODE = 7016 3/32"
TIPS: SOME PROCEDURES CALL FOR DCEN WITH 7016 WHICH MIGHT ACTUALLY WORK BETTER BUT REGARDLESS WHICH POLARITY WORKS BETTER, FOLLOW THE PROCEDURE
