Tig Braze Carbon Steel 1/4" thick surfacing beads silicon bronze
METAL TYPE = COLD ROLLED STEEL
THICKNESS =  1/4"
WELD TYPE = SURFACING BUILD UP
JOINT TYPE = BUILD UP
POSITION = FLAT
AMPERAGE = MACHINE SET TO 200 AMPS ...USING PULSE SETTINGS CONTROLLED WITH FOOT PEDAL.  ACTUAL AMPS AROUND 120-130
GAS FLOW = 20 CFH argon
CUP SIZE =  8
ADDITIONAL SETTINGS =    PULSE SETTINGS   1PPS, 40% BACKGROUND CURRENT, 50% pulse ON TIME
PRE FLOW = .2 SEC
POST FLOW = 7 SEC
