TIG BRAZING 14 GA CARBON STEEL WITH SILICON BRONZE FILLER CORNER JOINT WITH PULSE
sroll down for tig brazing settings
ceramic 12 stickout
After lots of experimenting with different techniques and settings using silicon bronze filler metal, these are the settings that I found to work best.
METAL TYPE = COLD ROLLED STEEL
THICKNESS =  .100"
WELD TYPE = FILLET WELD
JOINT TYPE = CORNER
POSITION = 2F
AMPERAGE = 109 AMPS USING PULSE SETTINGS CONTROLLED WITH FOOT PEDAL
FILLER WIRE = 1/16” SILICON BRONZE
GAS FLOW = 25 CFH argon
CUP SIZE =  12
ADDITIONAL SETTINGS =    PULSE SETTINGS 200 AMPS ON MACHINE 1PPS, 30% BACKGROUND CURRENT, 50% ON TIME
PRE FLOW = .2 SEC
POST FLOW = 7 SEC
