TIG BRAZING CARBON STEEL 1/4" THICK CORNER JOINT
scroll down for details and settings used for this tig brazing application
TIG brazing with Silicon Bronze filler metal goes better with a larger cup and gas lens setup .  A jazzy 10 or Furick 12 help keep oxides out of the puddle and things flow better
METAL TYPE = CARBON STEEL
THICKNESS =  1/4"
WELD TYPE = FILLET WELD BRAZE
JOINT TYPE = CORNER JOINT...SECOND PASS AFTER ROOT
POSITION = 1F
AMPERAGE = MACHINE SET TO 120  AMPS CONTROLLED WITH FOOT PEDAL
FILLER WIRE = 1/8” SILICON BRONZE
GAS FLOW = 20-25 CFH argon
CUP SIZE =  12
 PRE FLOW = .2 SEC
POST FLOW = 7 SEC
