TIG BRAZING CARBON STEEL 1/8" THICK WORN AREA SILICON BRONZE BUILDUP
METAL TYPE = CARBON  STEEL
THICKNESS =  1/8” WORN THIN
WELD TYPE = SURFACE BUILD UP
JOINT TYPE = PADDING
POSITION = FLAT
AMPERAGE = 110 AMPS CONTROLLED WITH FOOT PEDAL
GAS FLOW = 20 CFH argon
CUP SIZE =  10
PRE FLOW = .2 SEC
POST FLOW = 7 SEC
