TIG BRAZE CARBON STEEL TUBING 1/8" THICK WITH SILICON BRONZE FILLER AND PULSE SETTINGS
scroll down for exact settings used
METAL TYPE = CARBON STEEL COPED TUBES
THICKNESS = .125"
WELD TYPE = COPED TUBE JOINT
JOINT TYPE = COPED TUBE JOINT
POSITION = FLAT
AMPERAGE = MACHINE SET TO 140 AMPS USING PULSE SETTINGS CONTROLLED WITH FOOT PEDAL
GAS FLOW = 25 CFH argon
CUP SIZE = 12
PULSE SETTINGS 2PPS, 40% BACKGROUND CURRENT, 50% ON TIME
PRE FLOW = .2 SEC
POST FLOW = 7 SEC
TIPS: KEEP A FAIRLY TIGHT ARC AND WATCH TORCH ANGLE
Aim for an arc length that is equal or less than the diameter of your tungsten electrode. Torch angle can be forgiving provided your arc length is tight.
