TIG BRAZING CARBON STEEL .063" WALL SQUARE TUBE PULSE SETTINGS
scroll down for settings
Tig brazing is a useful process but you need to be aware that its not as strong as using er70s6 or s2.
It is very useful for making temporary fixtures as well as for ornamental applications like industrial furniture
TIG BRAZING SETTINGS
METAL TYPE = COLD ROLLED STEEL
THICKNESS =  .063"
WELD TYPE = GROOVE
JOINT TYPE = BUTT SQUARE TUBE
POSITION = FLAT
AMPERAGE = MACHINE SET TO 120 AMPS USING PULSE SETTINGS CONTROLLED WITH FOOT PEDAL
ACTUAL AMPERAGE READOUT WAS 65-75
GAS FLOW = 20 CFH argon
CUP SIZE =  10
ADDITIONAL SETTINGS =    PULSE SETTINGS   2PPS, 33% BACKGROUND CURRENT, 33% ON TIME
PRE FLOW = .2 SEC
POST FLOW = 7 SEC
