TIG CARBON STEEL EDGE BEAD ON .125" THICK COLD ROLLED
ceramic 12 stickout
scroll down for details and settings
primeweld 225 tig with stuff
The problem with most other really affordable tig welders is usually a really cheap foot pedal and TIG torch.  Primeweld went to extra expense to include a genuine CK17 torch with superflex hose along with a very smooth SSC style foot pedal.
A high quality CK dinse adapter is also included so that you can easily swap out a tig torch or cable when the time comes.
Primeweld also has a responsive primeweld equipment users group on facebook and also has demonstrated great customer support
Watch some more primeweld videos and you will see what I mean.
METAL TYPE = carbon steel
THICKNESS = .125”
WELD TYPE = SURFACE EDGE BEAD
 JOINT TYPE = EDGE BUILDUP
POSITION = FLAT
AMPERAGE = MACHINE AMPS SET TO 130 CONTROLLED WITH FOOT PEDAL (actual amperage readout was 60-63 amps)
FILLER WIRE = 1/16” ER70S6
GAS FLOW = 25 CFH argon
CUP SIZE =  12
PRE FLOW = .5 SEC
POST FLOW = 7 SEC
ADDITIONAL SETTINGS =  PULSE SETTINGS 50PPS, 33% BACKGROUND, 33% ON TIME
TIPS: KEEP A TIGHT ARC
