TIG STAINLESS STEEL EDGE WELD .050" THICK 304L STAINLESS
scroll down for details and settings
THICKNESS =  .050"
WELD TYPE =  EDGE WELD
JOINT TYPE = EDGE JOINT
POSITION = FLAT
AMPERAGE = 20-30 AMPS  MACHINE SET TO 50 AMPS CONTROLLED WITH FOOT PEDAL
FILLER WIRE = .045” ER308L
GAS FLOW = 20 CFH argon
CUP SIZE =  8
PRE FLOW = .2 SEC
POST FLOW = 11 SEC
