TIG WELD STAINLESS .050" THICKNESS AUTOGENOUS EDGE WELD
THICKNESS =  .050"
WELD TYPE = AUTOGENOUS EDGE WELD
JOINT TYPE = EDGE JOINT
POSITION = FLAT
AMPERAGE = 38 AMPS
FILLER WIRE = NONE autogenous
GAS FLOW = 20 CFH argon
CUP SIZE =  8
PRE FLOW = .2 SEC
POST FLOW = 11 SEC
