TIG WELDING 4140 STEEL TUBE INSERT .125" WALL TUBE FILLET
METAL TYPE = 4140 chromoly tube and chrome vanadium socket insert
THICKNESS = .125”
WELD TYPE = FILLET
JOINT TYPE = LAPJOINT
POSITION = 2F
AMPERAGE = 110-130 amps with foot pedal
FILLER WIRE = .045” ER70S2
GAS FLOW = 20 CFH argon
CUP SIZE =  12
PRE FLOW = .5 SEC
POST FLOW = 7 SEC
TIPS: KEEP A TIGHT ARC
