TIG WELDING CARBON STEEL COPED TUBE ROOT PASS .120" WALL
METAL TYPE = 1-1/2” CARBON STEEL TUBE
THICKNESS = .120” WALL TUBE
WELD TYPE = Fillet weld ROOT
JOINT TYPE = COPED TUBE JOINT
POSITION = 4F OVERHEAD
AMPERAGE =  120-125 AMPS CONTROLLED WITH PEDAL
FILLER WIRE = 1/16” ER70S6
GAS FLOW = 25 CFH argon
CUP SIZE =  12
PRE FLOW = .5 SEC
POST FLOW = 7 SEC
TIPS: KEEP A TIGHT ARC
